Please help with ECO design
when start ECODesigner, the Start Evaluation button can not use so what are problems with my system?
Thanks.
4 Replies 4
Read the manual which mentions this exact situation.
That button only becomes enabled after you have assigned material properties to the walls and openings, etc.
Karl
Karl
thank much
this exact the situation.
Thanks for posting back. Glad it was not a more complicated problem. 🙂
Karl
Karl,
I have the same problem. I tried to assign the properties to the structure, however in the BTU column there is an error sign and does not accept any changes.
Thanks in advance.
Ara
