Plot maker to AC20?
archigreen
How can I recover Plot maker files (AC 6.5) to ArchiCAD 20?
Thank you in advance.
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
Fra
Open the plot maker files with ArchiCAD 10, save and open with ArchiCAD 20
You can use ArchiCAD 10 packages files converter
Francesco
AC25 AC26 (Ita)
Mac Studio M1 Max 64 GB - OSX 12.4
Eduardo Rolon
and here are the links:
http://helpcenter.graphisoft.com/technotes/setup/compatibility-with-legacy-versions/converting-old-a...
http://www.graphisoft.com/downloads/fileconverter.html
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
We had this discussion just a few weeks ago... and AC 10 (converter or otherwise) cannot open plotmaker files from 6.5:
http://archicad-talk.graphisoft.com/viewtopic.php?t=53332
The File Converters can open PLN files back to version 4.5 ... but NOT LAY/PMK files. A gross oversight by Graphisoft. For 8.1 and 9 PMK/LAY files, there is this article on migration:
http://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/migration_guide_for_...
Here is a Wish to vote for the ability to open PMK files from AC 7 and earlier:
http://archicad-talk.graphisoft.com/viewtopic.php?t=53345
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
