Plotmaker 9 Import DWG? 2004?
I am trying to import a dwg file, but it is incompatible. I tried opening same file with AutoCAD 2000, and it did not open. Thus I am assuming it is in 2004 format. How can I import and export into AutoCAD later format? Is there an add-on for PM9 to make this import work?
Eric
3 Replies 3
Djordje
Download TrueDWGConvert (or similar name ...) form the Autodesk Web site for free. You can convert any DWG version to any DWG version.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks, the program is DWG TrueView. I haven't had a chance to try it, but it did look like it would work.
http://usa.autodesk.com/adsk/servlet/index?id=6703438&siteID=123112&DCMP=ILC-DWG-PUV
Eric
Djordje
That's viewing only. DWG TrueConvert is what you need.
http://newsletters.hagerman.com/newsletters/ebul47-Mech.htm
Djordje
HP Omen
