Problem to find components of trimmed composite walls
I have a problem to find components of trimmed composite walls.
· For that I am enclosing Acad17 file "Volume Components Problem.pln"
· And I am trying to find out components of walls. ( real world materials like bricks, concrete blocks, cement and Gypsum )
· Through "property objects could be setup to get similar values."
· Hence kindly refer "First Floor" plan that contains a room with four walls (trimmed by 4 beams and a slab)
· Where I am trying to find out quantity of No of bricks, No Of concrete Blocks, Area of Insulation, Cement bags required for Plaster and Gypsum required in Kilograms (All these are based and proportional to volumes or surfaces of individual skins of composite walls) required for one of the walls "SW-003"
· Also refer to pasted image of Excel sheet that shows formulae (the excel sheet "Components By Elements.xls" could not be attached because only one file can be attached)
· Now I will get "Component Quantities" if I use formula written in "Column E"
. I do not find GDL variables to be employed to get the components (i.e volumes / surfaces of trimmed skins)
Will someone guide me.
Thanks in advance
0 REPLIES 0
