Problem when exporting columns with veneer to IFC
Achille Pavlidis
I'm facing a problem when exporting my AC model to IFC, the columns that have a veneer (plaster) do not get recognized by the MEP software, and do not appear at all.
Anyone has the same issue? Is there a solution?
Thanks
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
1 REPLY 1
If you open the exported IFC model in a free IFC Viewer, does it display the Column and its Veneer correctly?
If not, the ARCHICAD export is the problem.
If yes, then it is probably something during the import of IFC into that other application, and you should contact them about it.
