Achille Pavlidis
Problem when exporting columns with veneer to IFC
I'm facing a problem when exporting my AC model to IFC, the columns that have a veneer (plaster) do not get recognized by the MEP software, and do not appear at all.
Anyone has the same issue? Is there a solution?
Thanks
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
If you open the exported IFC model in a free IFC Viewer, does it display the Column and its Veneer correctly?
If not, the ARCHICAD export is the problem.
If yes, then it is probably something during the import of IFC into that other application, and you should contact them about it.
