Propretie expression with multiple formulas
Ahmed_K
Mentor
Hello guys,
i'm trying to find a way to calculate material cost
I did the following : Check the attachement 1
it doesn't work...
second thing, can i use the function "if" to do the folowing inside the same formula ?:
if untit = m² ==> price per unit x area
if untit = mÂł ==> price per unit x volume
etc....
or i create a propretie with multiple formulas each one with seperated condition
i believe there is a way, i have tried several times without achieving a good result
Archicad 27
Windows 11 professional
4 REPLIES 4
Unfortunately, what you are trying to do is not possible in ARCHICAD at the moment, because Building Material Properties cannot be Expression-defined. Probably this is the reason why the Dialog says "Not applicable". This is a current limitation and I don't know if there are plans to develop it or not.
You can make a wish for this feature, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
Ahmed_K
Mentor
Thnak you LaszloNagy !
here is another thread, i posted something similar to this, talking about formulas in building material, it seems that ArchiCAD can't extract data from propretie when the BM is INSIDE a composite or something like it,
here is more details !
https://archicad-talk.graphisoft.com/viewtopic.php?p=309235#p309235
Archicad 27
Ahmed_K
Mentor
The link of the wish
https://archicad-talk.graphisoft.com/viewtopic.php?f=28&t=69484
Archicad 27
Great, you could post the link to the wish in the other thread, too.
I have added a Poll to your Wish.
