Publish to Sketchup
vfrontiers
Is there any way to use PUBLISHER to export SKETCHUP FILES?
Can't seem to find that as an option when publishing a saved 3d view...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Nuge
Just wondering if you found a way to publish Sketchup files, I have recently started using Modelo and it would be great to be able to publish sketchup files.
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
Not from Publisher that I am aware of.
Needs to be 'Saved As' SKP from the 3D window is the only way I know of.
The attached screenshot shows the file formats that Publisher can batch "save".
While SKP is not listed, IFC is ... and SkektchUp is capable of importing IFC files, potentially requiring a 3rd party add-on depending on which release of SketchUp you are using.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
