Recovering a test pln file from ArchiCAD 22 Beta 4
I have a “test project” file that I created in the Beta 4 version of ArchiCAD 22. Unfortunately this file was overlooked and not converted in the pre-release RC version of 22, which was since removed from the computer once the official release of 22 was made available. Also, the beta site seems to be shut down as well. So the question is how can this file be accessed? While the file is small, it is a real project and recovery is important.
3 Replies 3
...and this is the dreaded message...
Eduardo Rolon
You have to login into the Beta site and download the RC version this one will let you convert from Beta to regular files. AFAIK the RC version expires in sept.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Confirmed that the Beta site is now disabled (as stated by jfa_ra in his post), so there is no longer normal access to the RC version.
jfa_ra: Graphisoft can probably convert the file for you, or provide you with a link to the RC version. Contact one of the beta team from your initial sign-up emails, or go through tech support.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
