I have tried to use the door and window schedules that come with archicad to make a nice easy to read schedule with front elevations of each door and window types. I keep running into snags and everything that I need to do seems to be an un-editable characteristic of the element scheme. For example a garage door is much wider than a regular door but if I adjust the width of the display box on one door all the other boxes get wider too. Then they are all to wide except for the one around the garage door. I'm close to giving up and doing it all by hand like I did in the past. What do you other residential architects do?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
