Return "value" of generated parameter
Is it possible to read the value of a generated data created from a GDL expression.
For example I´m creating a simple object with the value (parameter) A and B
In the GDL-script i have the parameter C with i s scripted to be C="A"+"B" (just text)
When making a schedule with the parameter C as one of the fields it returns no value - which in one way seems logical since I haven't given any value to the parameter C. But is there a workaround to have the value "A"+"B" show up in the schedule?
You have set the value of your variable "C" in your GDL script.
But you have not set the value of the parameter (if that makes sense).
In you GDL parameter script (or it could be the master script) you should have ...
C = "A" + "B"
PARAMETERS C = C
C needs to be a text parameter of course.
The result for C will be "AB".
C = "A" + "B"
PARAMETERS C = C
Thank´s Barry!
It´s all in the details.
You can't imagine all the work this will save me!
/Fredrik
