‎2016-09-13 11:19 PM
‎2016-09-15 02:50 PM
‎2016-09-15 11:46 PM
laszlonagy wrote:I use the File Special>Merge tool because I want to have the building in my template. ArchiCAD seems to recognize that there is more than one story, but ArchiCAD doesn't seem to be able to give me the option to place the Revit stories on ArchiCAD stories.
Are you using the Open command and select the IFC file?
Or are you using the Merge command to import the IFC file?
You could try having the ARCHICAD file with the Story structure you need and then use the Merge command.
You could also open the IFC file in a model viewer like Solibri Model Viewer and check the project data structure hierarchy to see whether multiple stories exist at all in the IFC file exported from Revit or not.
‎2016-09-18 04:21 PM
‎2018-08-27 01:08 AM
