Foti
Rhino to GDL import visual issue.
I have several Rhino files that I am trying to bring into archicad25 as GDL objects. Each rhino file has one object.
When I open the 3dm file from Archicad (file-open-choose the 3dm file) the geometry and views from Rhino are there.
When I go (file-libraries-import-rhino file) i get a message the import was successful and is now a gdl object. I check the library it is there, but when I place it on a floor plan, nothing shows up, just a block dot. I open all layer and nothing. I select the black dot go to 3d view nothing there. Am I missing something?
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
3 Replies 3
Wlad222
Maybe your object is really far from the world's origin point in Rhino?
Foti
Hello Wlad222
Thanks for the tip, I had moved it to the origin in the 3d dwg and thought it would translate as is into the rhino. I removed it to the origin in rhino and dropped in Archicad and it worked. Thank you
Foti B.
AC25
Foti
One last thing, you need to explode the rhino before.
Foti B.
AC25
