2022-08-08
07:25 PM
2022-09-28
08:48 PM
Oleksandra Vakariuk
I have several Rhino files that I am trying to bring into archicad25 as GDL objects. Each rhino file has one object.
When I open the 3dm file from Archicad (file-open-choose the 3dm file) the geometry and views from Rhino are there.
When I go (file-libraries-import-rhino file) i get a message the import was successful and is now a gdl object. I check the library it is there, but when I place it on a floor plan, nothing shows up, just a block dot. I open all layer and nothing. I select the black dot go to 3d view nothing there. Am I missing something?
2022-08-09 11:01 AM
Maybe your object is really far from the world's origin point in Rhino?
2022-08-11 02:51 AM
Hello Wlad222
Thanks for the tip, I had moved it to the origin in the 3d dwg and thought it would translate as is into the rhino. I removed it to the origin in rhino and dropped in Archicad and it worked. Thank you
2022-08-11 11:29 PM
One last thing, you need to explode the rhino before.
