2007-02-06 01:16 AM
2007-02-06 07:15 AM
cremsberg wrote:Start with a good zone stamp, add all the parameters you are after, and then call these in the schedule. I will be posting this workflow next week on the ACE blog...
Element Schedule form the available list in the Project Map, but which one?
cremsberg wrote:It is odd. This is really up to the user community it seems. I am trying to make these tools and workflows available, with the help of many others...
it seems odd that a finish schedule is not already provided.
cremsberg wrote:Add them to the zone stamp object you have chosen to begin with...adding parameters is easy. Making them 'do tricks' is harder!
How can I add more User Defined fields than are available?
cremsberg wrote:The fields need to be editable in your zone stamp also, such as the FM/List parameters 'user defined' 1 thru 5 fields of most GS objects
Is there a way to make fields editable in the schedule when they don’t seem to behave that way already?
cremsberg wrote:Subtotal. It will add a line/row to your items...giving a subtotal of whatever you asked it to...while I'm at it, SUM1 is a dumb sum, SUM is a smarter sum (multiplies instances by value the sum button is applied to, ie. cost)
What does the little flag mean in the Schedule Fields list in Scheme Settings?
cremsberg wrote:Under 'scheme settings' go to 'import' or 'export' if you want to save this out for another project...sorry, no 'duplicate schedule' command...
Is there a way to merge a schedule from another file?
2007-02-18 02:51 AM
2007-07-11 10:34 PM
