Rough Opening Header Heights
I'm trying (very hard) to show the rough opening header height in my Door/Window Schedules.
Seems there's no option for Header heights, only Sill heights.
All the available schedule parameters will show the height of the unit, and not the rough opening height info.
For example, I want to show 6'-9 1/2" for a 6'-9" tall door unit, as an automated calculation in the Door or Window schedule...
Any help please?
4 REPLIES 4
In the scheduler there are two parameters for this, one for each side of the opening. (This is to account for situations using a "reveal".) They are:
W/D opening height on the reveal side
and
W/D opening height on the side opposite to the reveal side
When the reveal is not used these values will be the same. I'm not sure where the term "reveal" comes from as I believe it is called a "rebate" in the UK, and nothing (AFAIK) here in the US since our ROs are pretty much all straight through.
Thanks for straightening me out Matthew.
I had all my doors set with invisible reveals, that I didn't actually want, and these were throwing those header values all over the map. Once I corrected all doors to have "No Reveal" everything is looking cherry and those header parameters you described read fine now.
Hi Michael,
There are 3 types of opening size available for listing; wallhole, reveal and unit dimensions.
Edit the scheme settings, go to the 'Additional Parameters' button at the bottom, then navigate to the window/door of choice in the library. In the list of available parameters look for ac_wallhole_width, ac_reveal_width & ac_unit_width.
The wallhole dimensions should display what you need.
Thanks for your help, Peter.
What happened is I got thrown off by having all my doors set with "reveal" bevels, and this was throwing off the wallhole sizes. Once I switched back to the "no reveal" option for all doors/windows, everything made sense again.
