documentation of door window schedule!!!!!!!!
while documenting , in schedules , its easy to get the listing & 3d view / elevation of the doors / windows, but how to document the detailed dimensions viz: transom level,thickness of frame, width ofthe divisions/panels????/
5 Replies 5
If you need to add more annotations to the schedule your best bet is to place the schedule on a layout and explode it then copy that to a worksheet and document away. The downside is that it is no longer linked to the model and if you update you schedule you need to manually update this drawing.
i believe thats not the only alternative, with such an advanced software,
Srinivas
I am not sure, which version of ArchiCAD you are using, do add it in your signature so that users on the forum do know about it without guessing or asking you to post more details about your version and OS details. This is available in version 13, check it here.
http://www.graphisoft.com/products/archicad/pi.html
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
i am using archicad 12
There is the new Annotated Schedule feature in AC13, but that one is not yet available in AC12.
Here is a short video about the feature:
http://www.graphisoft.com/ftp/marketing/ac13/nfc/02/02.html
