.STL import issues
Dear all,
Recently I have encountered problem with my .stl files. I made 3D models out of pointcloud, remesh it to good value of quality/speed (approx. size 1-2mb).
In ArchiCAD, it turns out, that it is a way too heavy. I have change it for window frame (it is only possibility to make it work in viewport). Too bad, it gives this bad-looking frame (even if I change material for AIR). Any ideas, how to make it work? Please see the attachment.
All the best
Karol
2 Replies 2
Are you referring to the background frames around your statues?
If so does this help....
http://archicad-talk.graphisoft.com/viewtopic.php?t=54709
Barry,
Thank you for your response. I know this method, but this is modelled frame (appears in viewport when you highlight object). It won't go off after changes due to the render.
Karol
