.STL to .GSM Batch Conversion
I need to convert a large number of 3D objects to .GSM Format. I have them in various formats but the only one that is suppored by ArchiCad is .STL. I have just started using ArchiCad so is there a way to make this process automatic (macro/script like technique). The ArchiCad versions that are available to me are 17 and 20. I prefer the older one so that the .GSM file will have more compatibility.
Thank you in advance
4 Replies 4
Erwin Edel
There is the modelport addon (3rd party software) that supports some other formats that might help, but a mass library import option is probably not available anywhere.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I need every single .STL file to be exported in a separate .GSM. I believe this modelport addon will be helpful in a different situation.
Erwin Edel
You wrote you had some various formats, but only STL is supported by ArchiCAD, which is why I mentioned modelport, as it supports some other formats.
www.leloup.nl
What I meant is that I need a batch(automatic) conversion to .GSM using .STL or other 3D format.
