Saving as DXF- Saves file without any information attached
When I save an ArchiCAD as a DXF, it does seem to save something but when I go to open it nothing is there. The file size becomes zero kb. Do I have a setting wrong in my translator?
3 Replies 3
TomWaltz
That depends. What settings do you have in your translator?
Tom Waltz
Well I'm pretty much using the default translator... Is there a certain setting that you can think of that might not be correct?
TomWaltz
The Default Translator seems to assume that you are translating from Plotmaker (under "Save Options, it is set to "Paper Space with Cropped Drawings")
I'm not entirely sure that's the problem, but it might be a start.
Tom Waltz
