Schedule Presentation
Hi guys is it possible to have this kind of presentation of schedule in Archicad, if so, how??
Thanks a lot
7 REPLIES 7
Link
You can get pretty close, but you'll need AC13 to put the annotations into every window the way you have shown.
Check out Virtual Building > ArchiCAD Model Views > Interactive Schedule > Define a Schedule Using Scheme Settings, in the ArchiCAD Help.
Link.
Cant i do it in Archicad 12, is the version i'm using.
Thanks a lot
vistasp
Annotation within interactive schedules was introduced in AC13.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Srinivas
On a different note, If you use CADImage's Door and Window builder you can get a schedule like that.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Hi Ianas
There is a explanation in Portuguese here:
http://architruques.blogspot.com/2007/01/mapa-de-vos-para-alm-da-modelao.html
For Localização you use the zones
http://architruques.blogspot.com/2007/05/magia-das-zonas.html
For other fields (vidro, tranquetas, etc) you use extra parameters (see image attached).
Boa sorte!
Link
If you really wanted to get the windows images in, you could try copying the schedule to your plan (or worksheet) and manually editing it. I think you can just click in the schedule anywhere, hit ctrl+C and paste it where you need it. Then hack away. Messy, and very manual (it would require a lot of post editing especially when anything changes) but manageable.
Link.
Thanks a lot for your tips
