eldhead
Schedule coordinates
Pick coordinates from Survey Point and show them in a schedule. How?
Archicad 7 - 24, HP ZBook 15 Mobile Workstation, Win 10
3 Replies 3
If it is an object and the coordinates are in parameters in that object, then you can schedule the parameters of that object.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=68963
But it seems the survey point object does not have parameters for the coordinates.
So you will need another coordinate object.
Erwin Edel
I remember trying to do this a while back, but couldn't get it to work.
It was for a small project and only a handful of points, so I ended up typing out the list to save time.
Not sure if an object can 'grab' its position on the XYZ grid of the model, to be honest.
I couldn't get it to work with properties either (X coordinate and so on).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
An object can pick its own position and store the coordinates as parameters, so yes it is possible.
We are using a "homebrew" coordinate object at out office and that one can be listed in a schedule (even if it could use an update since it's quite old and a little buggy).
But here is also post asking for this kind of object on the GDL-forum: https://gdl.graphisoft.com/forums/topic/i-need-a-coordinate-object-that-are-schedule-able
