Schedules - Linked Parameters
I am inerested if Archicad is capable of linking parameters or associating parameters such as header, jamb, and sill details within the object so when a detail is generated and placed as a layout in plotmaker it links to those parameters, does this make sense?
I would love to have a detail somehow linked to parameter within an object!
Currently I am using 9 and will be jumping to 12. Prior to completing my schedule, I have to generate the detail, place it in plotmaker, then I have to go back and select the window, manually input the location of the jamb, header, and sill parameters. Any way of linking those parameters would valuable.
Kim
Djordje
You will be able to link the details in 12 much better than in 9 -not to the library part, but the markers and the detail tool is much more intelligent.
And, brace yourself- no more PlotMaker! On the other hand, PMK is back
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
