Schedules Search Criteria and Find Command
fuzzytnth3
In AC22 I have found that if you try to add an IFC Property as a search criteria in a Schedule or the "Find" command it immediately crashes ArchiCAD
Anyone else have this problem or is it just me?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
I do not see this type of problem on my AC22 version
I am working on macOS 10.13.6. Did you update your OS?
When AC crash I delete the Graphisoft .plist files from the finder in the folder library / preferences and library / application support
And then I restart AC but about your problem it seems to be more special
Perhaps it deals with your demotion to 10.12. How do you do this ?
Did you have installed AC22 before or after ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
There is a Find & Select bug that seems to have been fixed in the build 6000 update, which is in preview at the moment.
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=66620&start=10#p298287
The general release version of this update should be available in a few weeks, but you may be able to try the preview in the mean time.
fuzzytnth3
Thanks for that info :thumbsup:
