2017-03-23 10:02 PM
2017-03-24 01:27 AM
2017-03-24 01:36 AM
Barry wrote:Yep, I tried that as well, the strange thing is they where normal for the last weeks, so I probably changed a global setting because its affecting all the schedules, If only I new which one.
I can't say I have ever see a white fill in front of schedule.
But something you can try is to select the schedule (drawing ) in the layout and check in the drawing settings if the background is set to 'transparent' or not.
I always have mine set as transparent.
2017-03-24 01:51 AM
MombergNZ wrote:I am not sure what it could be.
2017-03-24 02:11 AM
Barry wrote:I use AC20 v5025 NZE (New Zealand version).
Model View Options, Graphic Overrides and Renovation Filters don't have any effect in layouts.
What version of Archicad are you using?
Does it print normally or as a white fill.
Something else to try.
If you can place a new schedule that is fine then ALT-click that drawing frame to inherit its properties and then CTRL+ALT click to inject them into the one with the white fill.
2017-03-24 02:16 AM
2017-07-20 03:28 AM
2017-10-25 10:46 AM
