Schedules from Section Windows
I'm trying to schedule of the areas of fills I've drawn in a section window for spacial separation calculations.
The schedule won't list the information!
I've done this fine for fills from plans.
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
4 Replies 4
insideru
As far as i know you cannot schedule 2d elements from anything but a plan view (no elevations, no worksheet, no details and ... no elevations).
What you must do is copy the fills on a plan and run a schedule from there. Yes, if they change, you need to delete them and recopy them from the section. Sorry
ARCHICAD 28 INT
macOS Sequoia
Thanks for the quick response.! I'll try your work around.
Thomas Allan Palmer
Thomas the answer you got is correct.
You can only schedule what is in the plan or 3D model.
And please try to post in a relevant section of the forum rather that 'Archicad +'.
The description for each section will hopefully lead you to the correct one.
Thanks.
Thanks Barry.
Thomas Allan Palmer
