Schedules with Sub-Headings
Elemental_BD
Hi All,
I use zones to calculate areas and table them using Schedules.
If I've got a multi unit site I want to be able to have one table with the areas for each part of the Unit listed under that Unit sub-heading; How do I about that?
For example:
Area Calculations
Unit 1
Ground Floor - Area
First Floor - Area
Unit 2
Ground Floor - Area
First Floor - Area
Unit 3
Ground Floor - Area
First Floor - Area
Cheers
1 REPLY 1
Name your zone like this and place on the appropriate floors: Unit 1 or 2 or 3 (figure 1)
Schedule these fields in this order, flag zone name to subtitle the areas per unit (figure 2)
Set the schedule to show headline (and hide subheads to be cleaner) (figure 3)
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
