Scheduling slabs problem
Tom Krowka
Can't get the schedule to generate slab info. Have set up the schedule using components. Have checked layers, renov. status filters, turned all layers on...nothing. It's like the schedule doesn't see the slabs.
Am trying to simply generare cover fill and conditional surface of the top.
Any clues to this? I'm sure I'm missing something.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 REPLIES 4
Why not using ELEMENTS?
Tom Krowka
I think I have a bug. When I select "and" nothing shows up in the schedule. When I select "or" elements show up. But I can't control other things in the schedule....it's all screwed up. Could you add some other fields and criteria and see if it works? I wonder if it's just my machine. Would appreciate it.
Thanks.
Thomas@wkarchwk.com
www.walshkrowka.com
Tom,
As andro55 notes, if you are looking just for top surface/etc you want an Element schedule, NOT a component schedule. A component schedule is for scheduling information about each SKIN of a composite slab.
No problems with either.
There is no bug with and/or that I know of. You will have to post a screenshot of your Scheme criteria settings for any of us to help you out. Note that there are parentheses available to use with the schedule criteria to make sure that your conditions are grouped properly.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Tom Krowka
Isn't the top surface the skin also?
Thomas@wkarchwk.com
www.walshkrowka.com
