Tom Krowka
Shedules w/ pics
After some experimenting, it appears the only way to make the schedules contain pics with any size pictures of the d/w is to make the schedule by columns.
Some of my d/w do not have pics, for reasons I cannot figure out. Am using the front view 3D pic.
Also, what's the best way to break the schedule down. I've got about 100 doors, and that makes one long schedule. How can I break the schedule down into pieces that I can get on the layout sheet and still be readable.
Should I make different views on the layout of the same schedule?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
Link
You should be able to see pictures with columns or rows. You just need to make the rows/columns tall enough. What doors and windows are you using?
To break it down, you can simply place one schedule on a layout and use the Restructure Table pet palette option to change it's size. You may have to copy the schedule onto another layout and use the offset edge pet palette option to reshape them.
Link.
Tom Krowka
When you say change it's size.....do you mean the layout or the schedule itself. Either I'm missing something, or the restructure table button does the same thing as stretch.
[email protected]
www.walshkrowka.com
Aussie John
Link means on the layout, the schedule can be stretched to turn a single column into multiple columns.
You can check the schedule box to group like elements so long as you havent gone the unique ID path (a great failing of the schedule in my opinion)
Cheers John
[/size]
