Tom Krowka
Size of d/w 3D graphic
Any way to change the door or window graphic in the schedule. It is supplied by the field "3D Front view".
Or is there another associated symbol that can be used.
Or another interactive way I can display the symbol? I have many doors; schedule will take pages if I do it this way.
Can't figure out a method to display schedule based on the front view that will include all it's door numbers associated. Is there a way to do that?
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
3 Replies 3
For the graphics size try changing the scale in the schedule's setting in the view map.
Thanks
As I know "3D Front View" can't show the associated symbol automatically. I usually the ID field to show door number ! It's not display the symbol in Door Elevation, but it's automatically !
So, looking for another interactive way, too!
Erika Epstein
Thanks
Tom , if I understand you correctly:
1. In the schedule Scheme Settings on the Fields tab you can choose front, back, 2D symbol,Axon or a Preview picture or you could eliminate this parameter if you don't want any symbol.
2.within the schedule clicking in any of the cells with the front view or other image makes the option "reduce preview to fit into the cell" available. You can then change the size of these cells.
3. I liked the idea of sorting by door type, but unfortunately all but the Preview are individual and separate views of each placed door. If you try to treat these views as a headline, then this parameter disappears from the schedule. Not to worry, to see it again just change its order in the Scheme Settings or Headline Settings so it is no longer a headline.
Unfortunately even the Preview Picture, has the same disappearing quality when assigned as a Headline. As these are stock photo images, this seems like it may be a bug, but probably not as this use of the preview image, since it does not show the choice of door panel, could be misleading.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
