‎2007-09-27 06:20 AM
‎2007-09-28 09:07 AM
ajg wrote:
Hi everyone,
I am messing about trying to import an SU model into AC_11. I can get the model in, with no problems, but I am encountering trouble when I try to define new rules.
For eg, when I try and tell it that oblique faces should be walls, the only option to select is Roofs. All the others are 'greyed out'.
If it helps, I'm running Vista.
Thanks for any advice- it'd sure be appreciated.
‎2007-10-01 01:47 AM
‎2007-10-01 10:20 AM
ajg wrote:
Necko,
Thankyou for taking the time to reply. I did read the help file, and I understand what happens upon opening an .skp file. However, there is also the option to manually define translation rules. Upon selecting this option, the notification regarding automatic translation of elements disappears. That is why I thought that perhaps you could define the translation of oblique faces into things other than roofs.
Perhaps I can re-define the imported elements? This would save me sometime, rather than changing all the wall to vertical elements and 'slanting' them in AC.
Any further advice/comments are welcomed.
Thanks again.
‎2007-10-26 10:27 PM
‎2007-10-29 12:12 AM
