Slab schedule
I am using AC for plywood-furniture design,
and have trouble with slab schedule,
I can't find a way to list dimension of the slab(like walls),
only surface, thickness and volume are available...
Any ideas how to list dimensions of the slabs?
2 Replies 2
Ok, I find out a way by myself...
if anyone have same question, here is a solution
I saved a slab as a library part
it is fully editable, so you don't loose any possibility,
and than list as object,
for objects you have length and width as a listing option!
Steve Jepson
good tip. I can use that for several things. Thanks.
