AlexV
Solution / workaround the updated xml format in Archicad 26 & 27 ?
Just discovered the updated xml format AC26 & 27 are using, while upgrading the dwg translators and I have to say this is the biggest downgrade I've seen soo far. Why something thas was a single line before is now split into 6 lines of code i beyond me.
And AC27 doesn't allow me to use older format xml anymore.
Here's a comparison between the translator as it was and after updating it in 27. 
The snapshot shows linetype conversions, but the real issue is layer conversion bc we have a system where each layer name ( based on all possible attributes: pens, linetypes,renovation etc.) is getting converted to 80-90 possible dwg layers, and my current translator upgraded to AC27 has 160k lines of code.
Does anyone know of a solution to work with the new xml format  in order to have it humanly readable?
Operating system used: Windows 10
BIM Lead @ BAU
Archicad 21-29
Windows 10 / Xeon W-2245 / RTX A4000 / 64GB RAM / 4K monitor
0 Replies 0
