aabdelrehim
Starter metric template
Hi everyone, I am very new to Archicad and has been working with shoegnome's free template as a start for my small projects.
any suggestions for a more comprehensive template? and not too expensive, i'm egyptian and the exchange rate is beyond crazy.
Thanks in advance
3 Replies 3
In my opinion you are better of creating your own template.
Use Shoegnome's as a start.
If you don't quite like the layers, add or delete your own or change their names.
Need new composites, create your own.
If you want different pen colours, change them to what you want.
Basically work through the entire template and set everything up as you want it.
Yes it is a big job, and you will never truly finish setting it up.
I am still tweaking mine after 20 odd years.
If you are working purely for yourself that is what I would do.
If you are going to be collaborating with others, then you may want to look into some kind of national CAD standard, maybe your local Archicad support can help with this.
Or get information on what the others you will work with have set up - maybe they already have a template they can share so you are on the same page so to speak.
Unless you have to collaborate with others, I believe you are better of setting up your own template.
I don't think there is any template out there (free or for purchase) that will actually suit what you want.
But that is just my opinion.
Unless you want to work in the way someone else is telling you to.
aabdelrehim
Thank you a lot Barry.
Erwin Edel
Quick guide / tips (going through attribute manager):
  • for layers try to stick to your national standard (assuming it exists) and add layers for annotation at different scales, layers for sections markers, elevation markers etc and layers for different type of zones
  • you want layer combination for plans, sections, elevations, details etc, most likely at 2 or 3 different levels of development stage
  • I would stick with the pen set your version of Archicad ships with. Reason being: if you load your library all the parts will assume certain pens are being used in a certain colour and pen thickness
  • Also stick with the default line types. I can't say I've ever added anything custom here.
  • For fills, also start with the default fills and add what you are missing. Do not change the default ones, because again: library parts will assume certain fills look a certain way
  • Start with the default surfaces and add what you are missing. There are more surfaces that you can add from the library.
  • Building materials: again start with the default and expand. I typically have 2 or 3 levels of priority 'strength' per type. For example concrete in a 500 range and in 900 range. You will find that you will need this to solve most common connections.
  • Populate composite and complex profiles only with the ones you will use a lot, or the list will become too large to manage. You will always add project specific composite / complex profiles, these should not all be in the template, in my opinion.
  • You will probably want zones for building type (residential, industrial etc), fire rated zones and room function (living space, corridor, etc)
  • The last attributes can just stay default (markup, cities etc)
After this we have setup a typical floorplan with gridlines and dimension and a few stories for the model.
Then we have viewsets predefined for the sections, elevations and floorplans. We have all the different design stages pre-defined here.
Finally, we have master layouts for different page sizes and pre-linked layouts for the design stages.
This is a very quick write up and rough guide. You will most likely find a lot of the same principles in Shoegnome's template, however his template would assume that you are using the US library and my guess would be that you have the international version and there might be differences.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
