2021-02-02 03:23 AM
2021-02-02 10:38 AM
2021-02-03 03:17 AM
2021-02-06 11:46 AM
2021-02-09 06:50 AM
2021-02-10 03:47 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-03-03 04:08 AM
2022-02-09 06:03 AM
SOLVED: I think I had this exact issue with no 'fix". The solution was to literally just zoom in. Above a certain percentage some fields aren't able to be edited. Go figure. What I'd really like to see adjusted is the ability to edit fields if they aren't currently active (ie: change the material of a sill even if it's unactive because there's one shown by default and I want to change them all to be a material listed as "---" when not in use)
2023-03-23 07:59 PM
RELATED SOLUTION: I had a similar issue with custom (basic string data type) properties that once were editable (working) in a schedule, but were later no longer editable directly in the schedule. After confirming all layers were visible, and unlocked, and that the properties could be edited on the elements themselves, I needed to completely re-assign those properties to that schedule since I had recently changed the name of the affected properties themselves in the property manager.
After simply removing the properties from the schedule through the scheme settings, clicking OK to confirm those changes, and then re-adding the exact same properties in the schedule's scheme settings resolved this issue for me. Funnily enough, other similar but different schedules in the same project file referencing the same properties did not have this issue, which led me to think something was off about that particular schedule. Hope this helps inform the developers somewhat.
ArchiCAD v25; Windows 10, solo .pln file accessed over a LAN network.
2023-12-15 02:45 AM
You'll never guess the solution: TURN ON ALL LAYERS
This makes no sense at alll
