Strange warning message while creating zones list?
Hi everyone!
I've been finally able to create my first zones list, which I'm extremely proud of, as you an imagine. And it works, wow!
BUT, whenever I open it, it gives me a strange warning message for each single zone (that's not a masterpiece I've done, is it?).
Pretty much it sounds like "Warning! Zone Category, Zone name!"
for example: "Warning! Main Zones, Kitchen!", "Warning! Main Zones, Bathroom!", "Warning! Secondary Zones, Garage!", and on like that.
However, all list calculations are updated and correct.
Any idea?
Thanks!
Enrico
here's a screenshot of the warning message.
undefined
If I see it correctly you are using the Listing function for Zones. It is also possible to use the Interactive Schedule to Schedule Zones. That is increasingly replacing the old Listing feature.
The error message comes from either ArchiCAD or the Zone Stamp object.
You could open the Zone Stamp Object for editing and check if there is any PRINT command in any of the Scripts that could send such a message. If not in the script, it may be ArchiCAD. In that case I would send this error to your local reseller.
