‎2020-06-25 10:07 PM
‎2020-06-26 08:57 AM
‎2020-06-29 04:15 PM
‎2020-06-29 07:56 PM
‎2020-06-29 10:31 PM
mcCad wrote:Of course you can with a good Revit IFC.
Ok so technically you can just open the file but you can't edit to add new components.
‎2020-06-30 03:21 PM
LaszloNagy wrote:Ok, I think I understand it better now, and the IFC format does it works with all version of Revit? Or do you need the latest version?
BIM applications have very different data structures and so perfect data translation and exchange with no data loss is practically impossible to do. So, for example, when exchanging files through the IFC format, the most successful approach is to use the exported IFC file as a reference in the other BIM application. This works very well. But I would not aim for direct conversion between Archicad and Revit, technology is just not there yet, and I don't know if it will ever be, although the Open Design Alliance (creators of the RVT/RFA converter technology used in Archicad) are doing everything to make the RVT file format as easy to read and write as they did with DWG.
Another trend that is emerging is the direct live bi-directional connection between applications (enabled by installed Add-Ons or Plug-ins), which transfers only data actually needed by applications. Archicad has such connections, for example, with Solibri, dRofus, Grasshopper.
‎2020-06-30 03:24 PM
Christophe wrote:Thank you for your help
Archicad is able to open an IFC by parametric import but all original IFC elements won't be able to be modify.
I'm often able to use good IFC files after having switched static IFC elements by Archicad parametric entities (objects, windows, etc). All begin with a good IFC : most of the time coming from Revit, I am disappointed.
‎2020-06-30 04:04 PM
mcCad wrote:Revit get this last IFC 2X3 certification at 26/07/2015
‎2020-07-02 03:28 PM
