2021-08-16
11:21 AM
2023-05-30
02:11 PM
Rubia Torres
2021-08-21 07:05 PM
2021-08-24 01:58 AM
2021-09-02 04:21 PM
Hello
You can use LAND4 add-on built in Archicad!
In this way, you can import surveyor data or point clouds (supports LandXML, .txt, .csv, .xyz file formats ). If the points are classified within the file by the surveyor, during the measurements, with specific codes - those can be also imported in Archicad, thru Land4. Not the least, you can place the imported points in different categories (also using different appearence for each category).
Basically Land4 transforms the measured points into 3D objects (points). From here you can go further and create break lines, contours, level lines, etc.
All Land4 objects can be used in relation with Arhicad classic tools.
Take a look here:
https://www.land4cad.com/land4-for-Archicad/
