Unable a zone from being recognised by objects
Is there a way I can make a zone frozen in a way that it is not recognised by objects. In our project we have many zones for different purposes and I would like most of them to be ignored by objects so that they get the properties from the zone I want to ( which are the zones who assign the names of the flats).
Thank you,
Eleni
4 REPLIES 4
Hello Eleni,
I use zone about different kind of area into different layers.
I use to modify one kind of them into hatch to keep area
Finally I use Zone without height to be not recognised by objects.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Hello Christophe,
Many thanks for coming back! Unfortunately, we need to keep different zones as zones in order to be listed in different types of schedules ( it is a complex project on an existing building so we need to show many different things in schedules, like which area is existing compared to proposed, which area is now Flat 1 or 2 etc which is a different zone, then schedules of objects etc). I tried making some zones 0 height hoping that they will not be recognised but it did not work... I do not know maybe I do something wrong there.
Thank you anyway, useful to know what other users do.
Eleni,
Just position your zones above or below your objects to avoid a link between them.
Christophe - FRANCE
Thanks, it does work; I thought it'd create some kind of superposition issue, but no, everything's fine with it.
