2009-01-07 03:16 PM
2009-01-07 05:20 PM
2009-01-07 06:57 PM
2009-01-07 07:04 PM
Peter wrote:Thanks, Peter - it is here now.
This post should really be in the 'Schedules' section, so perhaps a moderator should move it for you, and you may get more responses.
2009-02-05 12:14 PM
2009-02-05 03:29 PM
2009-02-05 11:07 PM
2009-02-08 12:16 PM
Rick wrote:It depends very much on what kind of work you do, and how organized you are about it.
I may be wrong, but with Cigraph's version it requires re tagging/linking all the time, for each pln. When tried the add-on (and maybe not enough), it seemed impractical to use in the long run.
2009-02-10 01:07 PM
Rick wrote:Rick,
It is a big undertaking, but AC can do a great job at it. The interface suffers tremendously, as does the instructions. I haven't read that book, but if I were just trying to learn it, I sure would get it. As above, a lot has be discussed on this forum, and I know if you search my name you will find a lot of info. Ask for specifics, but a lot is here you can fine. I have uploaded a simple booklet someone did a long time ago. You can download it (link below). It is a start, but plowing through it is painful and necessary until (if) GS does something about it, which I am doubting more and more. The interface is about the oldest part of AC that exist, and is still virtually unchanged since the early days.
http://www.thompsonplans.com/files/TappingCalcMenu.pdf
On my web site, under any plan is a sample of how it works for me. I use Excel to format the various list I generate. AC is ridiculous at it.
2009-02-10 01:26 PM
Wrathchild wrote:Download works here. I suggest you try again.
I clicked your link but only got from page 10 on of your pamphlet.
