Hi Giuseppe,
It seems that Doors do not have this parameter so you will have to modify the Doors in your Project.
Here is how to do it:
1. Select the Door on the Floor Plan and use File\Libraries and Objects\Open Object to open it for editing.
2. In the Library Editor Dialog, click New to create a new parameter for the Door. It will appear at the bottom of the list of parameters.
3. In the Variable field enter
WallThk, in the Name field enter
Wall Thickness.
4. Click the Parameter Script button on the Left to go to the Parameter Script of the Door.
5. Enter the following in the Parameter Script:
PARAMETERS WallThk = WALL_THICKNESS
6. Save your changes.
Note: If your Door is in an LCF file, you will need to save it under a new name because you it cannot be saved back into the LCF file. However, in that case you would have to change all instances of the Door to this new Door object. So the best would be to first extract the LCF into a folder, load that folder as your Library, open the Door for editing, save changes and then you can recreate the LCF if that is better for you (in that case the standard ArchiCAD Door will be overwritten).
So basically what these above steps do is they create a new parameter for the Door into which will be loaded the value of the thickness of the Wall enclosing the Door.
I tried it and it works for me on various Wall thicknesses.
7. Create your Door Schedule similarly to the Window Schedule by adding this parameter of the Door to the parameter to be listed.
