Window Legend/Types - How to create custom?
ArchiCAD comes with a generic window legend. I'd like to create one (maybe using that as a starting point) that I can customize. How do I go about doing this? Generic one attached.
I'd like it to only show the view from the exterior, currently it shows the interior and exterior overlaid.
Also, is there a way to exclude some windows from this legend? I have some existing windows I don't want to show up.
I also want to change font etc.
Thank you,
4 Replies 4
Ok, after a bit of digging I found out how to exclude certain doors/windows from a schedule. Very helpful.
http://archicad-talk.graphisoft.com/viewtopic.php?t=32626
I will dig more and see what I can come up with...
Ok, I was able to somewhat achieve what I want using the schedule tool. It looks ok. The one huge problem I have with it is that whenever you click on it or go to the sheet it's on it takes a huge amount of time to update itself. Schedules are sooooo slow. You should be able to achieve something like this as a list, correct?
How are people doing window types? Do you create them in the schedule? Does anyone use element lists?
Yes, I was use some time the element list of windows and doors for other building object too.
It is quite complicated, but i found some ways how to do it.
I did not have enough time work on it.
If will some one would like to found solution how work on it I will tray to found time to joint on this work.
visit this forum question:
http://archicad-talk.graphisoft.com/viewtopic.php?p=160368&highlight=#160368
