I'm having a bit of an issue with the unit precision that displays in my window schedule.  I am using Marvin Windows, with frame sizes of 2'-1 3/8" wide x 4'-0 3/8" high or Half-Round with 2'-1 3/8" W x 1'-0 11/16" H.  I need these dimensions to show correctly in the window schedule, but it always rounds to 1/2" or 3/4" instead of the 3/8" or 11/16".
After searching through the forums, I discovered and changed the project preferences > dimensions settings to the 1/16th inch precision that I need, and that worked fine for the schedule to show correctly on the Project Map, but once placed into the Layout Book, it reverts back to the 1/2" and 3/4" rounding.  Is there some other way to change the unit precision of the Layout Book independently of the Project Map that I am missing?
We tried to get the Marvin download files to use instead of the default ArchiCAD library parts, but it is a .pla file and anytime we try to open it on our Start Edition it gives us an error that "START edition cannot read this document version. (10.0)."
