Window Schedule
Is there a way of multiplying area and number of windows within the schedule in Archicad 20?
You can sum the areas by setting the "sum' button next to the area field in the schedule settings.
Apart from this simple summation and a count of elements, the schedules can not perform any other calculations.
Thank you, Barry,
apart from this, do you know if there is a simple way of calculating the perimeter of all windows in the project?
And i have a big problem with insulation turning. I'm making a model and i want to show two types of facade. Existing one (without insulation) and a renovated one (with insulation). When i set model view on CORE only or Without Finishes, it simply doesn't display the windows correct in facade and plan.
And the last one. For the terrace window-dooor. I want to have a dimension marker for both - window and door, and not the whole window Door? Is it possible?
