MitchDes
Window and Door Lists
Hi, This might seem unusual, but can anyone tell me how i can have a door appear in a window schedule instead of the door schedule. Is this possible? If so how? Thanks
Using ArchiCad Start 2020 On PC With Ryzen 5 5600 6 core, 16Gb Ram, 64bit Windows 11, Nvidia RTX 3060 Ti, 32"; Lenovo Monitor; 1920 x 1080 Res
3 Replies 3
The first thing would be to set the criteria of you schedule to look for 'Element type is door' OR 'Element type is window'.
This way it can find both at once.
But if you only want one particular door then you will need to add more criteria to filter for the object name or maybe a specific ID to be more particular for just the door you want.
You will want the 'Element type is door' and the other refining door criteria to all be enclosed by brackets as you want that bit to work as one filter for just the doors.
Something like this...
MitchDes
Great idea, thanks i'll give it go.
Another way is to change the Classification of the Door to "Window", and change the Criteria to list elements with the Classification "Window".
