Eric Bobrow
Working around the limitations of Property Expressions
I'm trying to see if I can work around some limits regarding the new Formula expressions for Properties, which seem to only allow calculations based on the built-in element attributes along with hard-coded numbers.
Does anyone know:
Is there a way for a Property formula to pull data from a standard GDL parameter of a library part OR the Property Object associated with an element, and use it in a formula expression?
Also, is there a way to use a Global GDL script to pull data from a CSV or Text file and make it available in a global array that could be queried and accessed in other GDL scripts?
These are the ideas I have for possibly accessing external databases of cost information to get cost reports within ARCHICAD.
Thanks in advance to anyone who can give me a clue about how or whether these things are possible.
1 Reply 1
Erwin Edel
I think you can only work with a fixed set of parameters and properties in the Expression Editor.
That said, if you would make a list of 'element' costs properties for m1, m2, m3, piece etc, in theory you would be able to make schedules with costs if you fill out those fields in ArchiCAD.
However I find it quicker to fill out the quantities in Excel, derived from a well set up schedule, since there still are quite a few things that need to be taken in to consideration for costs, that make little sense to model.
One way or the other, you are inputting data / numbers in to a field of text/data. Favourites would streamline some of this, but in practice during design, things get changed around quite a bit, and whatever was put there from a favourite settings (cost per m2 or such) will likely have changed by the time you get to the cost calculation phase.
While it is possible to get data in to an object from a text file or such, I think this method is a bit crude, but maybe someone with more experience can help out here.
Going back and forth between excel and archicad schedule with Properties is working quite fast, unless you are trying to import back a spreadsheet with a few hundred fields of properties.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
