2006-03-18 12:49 AM
2006-03-18 03:49 AM
2006-03-18 04:02 AM
2006-03-18 01:52 PM
2006-03-18 02:21 PM
2006-03-18 05:00 PM
2006-03-19 05:34 AM
2006-03-19 08:17 AM
Ignacio wrote:This sounds very interesting. What is the input method? One guy on a laptop? If this could be made to work with an electronic whiteboard it could be even better. Thanks for the info.
I have seen ArchiCAD work very well for discussion and markups in meetings (this was Russ Sanders from Orcutt Winslow) using
1- a projector, and
2- the 'Active Layer' trick (only way to get there I know is going to Work Environment > Toolbars, 'Commands by Theme' > Add-Ons, and putting that in a toolbar), so that everything you draw using any tool goes to a given ad-hoc layer (say '*coord mtng 060318').
2006-03-21 06:41 AM
Matthew wrote:The guy on the laptop. The lights turned off so everybody is focused on the projection screen, and the 'markups' that are not lines or text are modelled on the spot, quick and dirty, sometimes in bright materials. A lot of walkthrough and spinning the model around and switching layer combinations. It is pretty impressive. Best use of ArchiCAD for communication/coordination I've ever seen, and for that matter best communication/coordination setup I've ever seen also, by far.
