davdelven
Wrong UNICLASS 2015 En Table October 2020 xml in BIM Data Portal
There are missing Codes in the updated UNICLASS 2015 En Table October 2020 in the BIM Data Portal XML file.
(see attached image)
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
2 Replies 2
I will report this to Graphisoft.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear David,
Thank you very much for your report! It turned out that NBS made some small changes while keeping the same build version, therefore we were not aware of the changes. We updated the XML in our website to reflect this change!
Thank you once again for your report. Let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
