‎2007-05-17 07:15 AM
‎2007-05-17 10:07 AM
‎2007-05-17 03:04 PM
Link wrote:You're right. The DWF In-Out and the DXF-DWG In-Out options in my add-on manager both have a red triangle with an exclamation point in it. The message states "The file is an outdated Add-On that cannot be used with this ArchiCAD version."
Sounds like your DWG/DXF Input/Output Add-on may not be loaded. Check it in the Add-On Manager from the Options menu. You should be able to load it from ArchiCAD's Input/Ouput Add-On folder.
Otherwise it may simply be a Work Environment setting, in which case you should try a new profile, or at the very least a new command layout scheme.
Link.
‎2007-05-17 03:15 PM
‎2007-05-17 03:52 PM
Link wrote:Sorry about that. I'm on version 10, running on Windows XP. I was still pointed at the correct folder, but I tried to reload them anyway. It didn't resolve the issue.
No idea what version you're using or which platform. Have you tried reloading them from the correct folder?
Link.
‎2007-05-20 02:10 AM
