2015-01-20 02:59 PM - last edited 4 weeks ago by Molinda Prey
2015-01-21 01:18 AM
2015-01-21 04:40 PM
2015-01-21 04:43 PM
2015-01-22 08:14 PM
2015-01-22 08:23 PM
2015-01-22 08:36 PM
2015-01-22 08:38 PM
2015-01-22 08:39 PM
rob2218 wrote:Yes, if you bring the DWG as a Drawing, it will not bring its attributes into ArchiCAD's attribute set - a cleaner solution.
Also...isn't the whole hangup about inserting a DWG as a "Drawing" vs. inserting it as an XREF DWG ATTACH the whole "layer" issue?
Right now I have the DWG xref'd into ARchicad. Throws all sorts of additional layers in my Archicad layer list I DO NOT want to see.
It's my understanding that I can simply bring in that same DWG as a "Drawing" grabbing it form an external source, place it in my layout and the layer list wont be populated...is that not the case?
2015-01-22 08:41 PM
laszlonagy wrote:rob2218 wrote:Yes, if you bring the DWG as a Drawing, it will not bring its attributes into ArchiCAD's attribute set - a cleaner solution.
